There are scenarios in which it is desired to configure some MAC addresses as static so that they are not subjected to MAC moves. In such scenarios, these MAC addresses are advertised with a MAC Mobility extended community where the static flag is set to 1 and the sequence number is set to zero. If a PE receives such advertisements and later learns the same MAC address(es) via local learning, then the PE MUST alert the operator.
Remove static MAC if necessary.
Warning
EVPN Entity %EVPNEntity% has detected a sticky mac %srcMAC%.
| Name | Type |
| EVPNEntity | uInt32 |
| srcMAC | srcMAC |
